919 flat-amp...
ghamilton
My 919 was made in april of 1980. The flat-amp section has no black flag caps in it. I've heard of other 919 amps that do have black flags in the flat-amp. Which would be more common?
Also, there is none of that sansui glue anywhere in my 919.
What do you guys think?
When I recapped mine in July, I changed C01 (33pf), and C35, C36, C37,
C38 (all 3 pf).
Helios
I found black flags on the driver board & the MM phono board. I changed all of them to silver mica. I could spot black flags in photos of other 919 flat amps. But no black flags on my flat amp board. Perhaps they used something else in those places. I am sure that I am the first to recap this 919. No sansui glue either!
It came off the line in april of 1980.:yes:
I guess I'm losing my mind. I took the tops off today and there they were. New silver mica caps in the flat amp. My stupid mistake. There is a lot of stuff in there. It's hard to remember all those details.
Thanks Guys.:screwy:
Black flags were also on my flat amp, now all replaced.
Good job. I noticed you kept the old trim pots too. I just sprayed mine with deoxit. I did change them on the driver board though. I wanted to be extra sure that the origional outputs were safe.
My board recapped. Surprising that you did not see them ghamilton. There are a few that I did not replaced, because of my lazyness.
Helios
