Dearslayer
I'm replacing all the lamps in this 9600 and I've done the meter and dial lights and I just started the indicator lamps. I got these lamps from David ( Dojo ) I installed the first input lamp and I wanted to try it to see if it worked before proceeding with the others ( I have all the others removed from the board ) and the 4amp fuse blew! Was it installed backwards for the fuse to blow?
