The 9849-8B first up because all I have to do is install the drivers.
Yes, the woofer baskets are white, they started life as 417-8H drivers. I had them reconed as 414's years ago.
Used them in some quick and dirty boxes for my son. Got them back because they were too big and fugly for his new home. I put the vented dust caps in last week because the recone guy used non-vented caps. They actually have real Altec cones in them as far as I can tell.
These had the rare 806 style HF drivers with tangerine phase plugs and the lightweight diaphragms. Those drivers are now in my Model 19's. So, these are getting the 902-8A from the 19's.
Original crossovers are in place. I'd kind of like to try some Model 19 crossovers as I have a pair in stock.
The horns are plastic. One has an aluminum brace on it.
Cabinets are a little rough, one was hung from a ceiling. The other has a spatter finish. I figured I'd listen to them for a while then figure out how to paint them. If you have any suggestions there, fire away.
The 9846's are completely disassembled. Cabinets got a little water on them here and there from a slight basement leak. Swells up that particle board quite well. They will also need paint. And Bondo.
I'm missing one N501-8A crossover. And the woofers need cones. From the "aftermarket cone" thread, I mentioned that I bought recone kits. The more I look at those, nothing is like the original parts, and when done the driver won't perform like intended. Not to mention, the cone does not fit over the voice coil, at all. I test fit the parts. Going to be a $200 mistake. It won't be my first.......
Onward and upward!
Ron
