From the "dissection" in here looks like four dropper resistors around 3,3 Ohm 2 Watts each in series with each tube's heater should do the trick.Would anyone here help me fix the heater voltage?
Thanks, Danny.
Did you really expect a real tube amp for $99? Or even $299?
Most of the time you really do get what you pay for.
Pins 4 & 5 are the heater. It doesn't matter to which of these you'll connect the resistor. You might use pin 5 because being in the very middle it is easiest to locate without mistake. Any type of resistor is good: 2 Watts or more, they will get warm to the touch so don't let them rub against electrolitic caps.That sounds pretty simple. I should be able to do that. Will it matter if I put them on pin 4 or 5, and is there any particular type I should use over another?
Also, thank you Gary, for your help and being positive about the little china girl.
There is usually someone on AK that can help more than the knockers.
Danny.
Your amp is fine and might sound great with its tube stage and toroid transformer in the power supply. She has good looks and good connectors. People just got ticked off at the original false advertising. Which is nowhere near the famous Golmund vs. Pioneer ripoff.
Simple phono preamps are available in kits. Dick Smith folks should be able to tell you who still sells kit sets in Australia.It is a pity it lacks a phono stage, thats my biggest dissapointment.
Or, a couple of preamps (one for each channel) like these could do it.
i hope yours last longer than mine...it lasted 3 days before it would not come on anymore....
Jumpers with two solder points are easy to remove without damage to the traces, use pliers to lift them off - don't burn your fingers.I have difficulties with de-soldering. I can do it, I just dislike it...
Should I cut the trace with an "exacto" knife?
Exactly! Today very often I find better quality stuff at thrift stores and flea markets than the "brand new" crap at the stores. Although technology gets obsolete real fast.Items that were made here lasted years.
EXACTLY why I would never buy one. I buy and use a lot of different products in my maintenace dept at work. Due to changes in our manufacturing and buying here in the states I'm stuck with over seas junk. Items that were made here lasted years. We are lucky if the new junk makes it through the job at hand. I'm forced to buy three times what I used to because one of three items won't work right out of the box. Sorry for the rant and tangent from tube audio. This one just struck a nerve![]()
Aussiedan, have fun tube rolling with that amp. Let us know what tubes sound the best.
After the mod check the the voltages across heater's pins 4 & 5. It should be 6.3 Volts or real close to it. The dissection page said heaters run on AC, so a true RMS meter would be very helpful - try to borrow one since these meters are more expensive to buy.The fact that Valve amp's one only lasted three days has helped prompt me to try and fix it. I hope I get more than that.
If you get a couple more 3.3 ohm resistors (same type) you could add them in series with the smaller tubes' heaters. Like the turquoise color ones in the pics below. You might be able to genty pry the jumper with a small screwdriver while applying the soldering iron from the other side - without removing the whole board again.The 2 6P15's seem to be running nicley. The 2 6N1's still seem a bit bright, particularly the little guy on the left.
