A/D/S L810 and L710 Fuse Holder Caps
Bsteele
I grabbed 2 pairs of ADS the other day. L810 and L710. Good condition overall. Except that the fuses and the fuse holder caps are missing, therefore no tweeter action!
I have been trying to figure out which fuse holders are used so I can track down the correct caps.
Looking closely, I saw that the fuse holders say "Littelfuse 345 Series" in very tiny writing. Thing is, there's many different fuses that fall under that category by Littelfuse.
I've also looked around for a good photo of someone else's L810 or L710 rear panel to see what the fuse cap even looks like. No luck. There's a few different versions of this speaker and I'm getting confused about which one I even have.
There's another old thread by someone that had the exact same issue, however, many advised that they change the full fuse holder. I'd rather not open up the speakers to do that. They're in such good shape, I don't want to mess around. (https://audiokarma.org/forums/index.php?threads/ads-l810-missing-tweeter-fuse-question.934620/)
Does anyone have any insight? Or a photo of the rear panel of their L810 or L710 with the fuse holder caps that would match mine?
I've attached a couple photos. Thank you all!signal-2021-06-22-130530_002.jpeg signal-2021-06-22-130530_001.jpeg
Go over to Parts Express and look at the
Littelfuse 3AG Panel Fuseholder
I believe that it's the same horrible springy T-eared fuse holder that ADS used originally. Just take the cap off and mount it in your existing fuse holder.
OR you can replace the whole thing with a screw cap fuse holder (cap threads on) so that your heirs won't curse you.
Your crossover looks like you will need to take the lower woofer out to get at it. I can't fin any pictures of that model
Thank you SO much.
I just found this blurry photo online of someone else's L810 panel actually. It looks like the same one that you've shared. I appreciate your help so much.xEhVnv0.jpg
