Hello everyone,
I've dipped a toe into trying to repair an amp but I've got stuck and need a little advice.
I fished an NAD 3020 series 20 amp out of a municipal waste tip hoping someone had tossed a perfectly serviceable amp. I got it home, wired it up and sadly it wasn't. Switching on produced a nasty buzzing noise with the music along with a flickering power led. This buzzing is loud with no volume and then is pretty much gone with increased volume. Oh dear.
I googled about for solutions and came by forums posts saying things like bad capacitors or even a simple blown fuse could be the problem. So I opened it up and the fuses were good although the power caps had some of looking dark residue at the bottom of them. At this point I felt like I was out of my depth and best get someone with a clue to look it over before I do more damage.
So I took it to a local repair shop and for £20 they told me the board was cracked near the speaker terminal and the caps indeed look bad but after that who knows.
Fearing this free amp was gonna cost alot to repair than it's worth I thought I'd try figuring out myself what's wrong and learn something on the way.
Anyway after patching a couple broken traces and recapping the board I plugged it back in to some scrap-able speakers and... still buzzing and no left channel. Ah crap.
Back to the forum to see if it could be something else, checked over diodes and the bridge rectifier which *i think* are fine I now think the missing left channel is due to a broken terminal connection which seems to have gone after I reflowed the terminals solder but the buzzing is where I'm stuck.
I found posts mentioning that the power switch on these amps can break and cause an arc of AC which I'm guessing is the noise I can hear from the descriptions, the flickering power led seems to be somewhat of an indication of this too but I don't know how to check the switch.
I've checked across the terminals for continuity and all I get is a reading across the two rear terminals regardless of the switch in the ON or OFF position. What should a healthy switch read or do I need to check it another way.
I saw that leesonic replaced his switch with one from Mouser (612-P197SBEE) and recommended a to replace the ceramic caps across it too.
Which type of caps should I use?
Is this switch ok to use instead of the mouser part? And would I need to connect it in a different way to the way the OEM switch is soldered? -
http://www.conrad-electronic.co.uk/...P1TL-6SASHA-latch-1-pcs?queryFromSuggest=true
Any help will be really appreciated!
