Just got done restoring this using a lot of Leestereo tips......but have an issue of low volume on the left channel....... no static/distortion, just a lower volume.
The unit was pretty clean & all original, complete with glue, lol. I've seriously sprayed & worked all the pots/switches (except volume pot), it has new ON Semi outputs/drivers on both boards, fully recapped, new relay, glue removed, glue-damaged components replaced etc.
I got it in a "no power" condition..........someone had been in there, as 3/4 fuses were blown & the 4th was missing, but no components were touched. I found that one channel had shorted outputs/drivers, & the other had 1 shorted driver but the outputs were good.....odd.
Anyhow, it now looks good on paper.......55.2 volts/-55.2 volts at main caps.......DC offset is 1-3mV & bias stable at 20-21mV.
I'm using a tablet as a source & have found: Swapping L/R inputs of "AUX" , TUNER" , "Tape 1" had no effect......still low on left. Using "amp in" produced a balanced, solid sound. So can I eliminate 2721 as the problem? I'm trying to learn more. Per the schematic, I would "anticipate" the problem to then be on the tone board 2720.......... am I in the ballpark?
