A new turntable?
jtboik
Should I invest in a new turntable? I just dug up about 30 or so LPs and about 20 45 rpms from my grandma's house. My parents got her a new Crosley CR47 after the 45 year old one finally gave out. We have used it about 3 times only.
I bought 3 vinyls from ebay in very good condition even though I don't have a turntable.
I want to play the records, but from what I've heard, Crosley turntables are terrible and may even ruin records. I want to keep the records for a very long time, so ruining them is out of the question.
The main point is, Should I get a whole new turntable, or risk using the Crosley?
I'm looking at the Pioneer pl-990 or sony PS-LX250, both of which are around $100.
I may even get a USB turntable, to transfer to digital, but I have a lot of the Lps in digital already.
I'm also still deciding if I'm even interested in collecting vinyl or not, but the first thing to do would be getting a record player!
Thanks!
I think I may try the Crosley on some records, but I don't think I'll let it touch the important things(Led Zeppelins, Rolling Stones, Dio), until I get a new one!
With the budget you are talking about I would recommend, very strongly, a used turntable from when records were still very popular. You can get a nice vintage turntable for that, which will clobber the cheapest of the new ones out there (but they will be better than the Crosley, as pretty much anything is). There are excellent turntables being made today but they are pretty expensive. Cheapest of the ok ones seems to be the Audio Technica SL-1200 clone, which I believe has a built in phono preamp.
PS: Welcome to AK!
PSS: The plural of vinyl is vinyl. Not vinyls. Its just a sore point with a lot of vinyl collectors :)
PSSS: Yoshi rules.
If it works and doesn't need a new stylus (needle), it would be much better than the Crosley. It would be a good starter table until you could afford something better. The link below will take you to the TT page on vintage Technics. There are better Technics tables out there though. Good luck with your quest.
http://www.vintagetechnics.info/turntables.htm
First, and most importantly, welcome to AK!!
Second, ditch that Crosley (took a lot for my fingers to even type that name)!!
Third, yeah, call 'em records, LPs or vinyl but try to avoid vinyls. Kind of a fingernails on the blackboard thing in here, if you know what I mean.
Fourth, IMO your $100 can buy you a better turntable than the SL-BD20. They're going used on ebay for between $18 and $42.
I know I can get something better, but I think I might start slow get a very nice one later on.
Pioneer PL12D. excellent mid range deck, underrated and easy to pick up for cheap. may need a new belt - again, easily available online.
The 1980's sony DD models like the PST-15 and -22 also tend to be problem free and easy to find.:music:
I would remove the ebay link or this thread will be moved to Dollars and Sense by the moderator.
Where are you located? There are lots of nice folks here with many turntables and knowledge of their local market. If someone is local to you they might be able to suggest something that is a good deal and that you wouldn't have to pay to have shipped. (Shipping turntables is expensive and risky...)
+1. Get local and avoid shipping. Listen to it before buying and be sure it works well.
Also, if you are new to vinyl, get one from someone who knows how to set up the cartridge properly. An $50 turntable with $50 cartridge that was set up properly will sound better than a $100 turntable with $100 cartridge.
+1 :thmbsp: the pioneer pl-12d is not only simple and robust but is also widely available..
with a careful lookout but you can pick up a 'mint-ish' example often for peanuts...
it has a good tonearm that happens to mate very well with the excellent value at95e and with some mild tweaking and finetuning you will have a rather good sounding vinyl player that will last for years to come..
One thing about a turntable is that you will need an amplifier with an appropriate input.
The Pioneer PL12D will no doubt have a Moving Magnet type of cartridge (the standard since the mid-60's) and you'll need a "phono" input on your integrated amplifier or receiver.
Earlier turntables had ceramic cartridges which were (arguably) inferior and used a different sort of input.
