tensleep
Addicted Member
What is used to generate the tone? (I've heard of "tone generators" used for troubleshooting phone lines--is it something similar?)
Thanks.
SubLover
I use a simple application I downloaded from the internet (don't have it on this computer, don't recall the name right now). You should be able go Google a free application. Hook your audio out from your computer into an amplifier. Hook the speaker being repaired to the amplifier output. Using the application, generate a 100hz tone and amplify it through the speaker. Turn up the volume so that you can hear the hum at about normal speaking levels (less if you are an infommercial advertiser). This will create a strong enough magnetic field to center the voice coil.
http://www.world-voices.com/software/nchtone.html
I have no affiliation with this application. I have not tested it either. This link is just an example of a free tone generator application.
Finally, as stated earlier and in my opinion as well, refoaming is a manual process. I have no experience using a voice coil shim, so I cannot comment on how that would work. I did work with my surrounds, baskets and cones for about an hour while the glue set, with the tone generator on, and have had had no issues with voice coil rub. So far, I have refoamed two paper cones and four poly cones this way.
