ken kantor
Fowl Humor
When Efficiency, When Sensitivity?
OK, after a bit of research, here is what I have come up with.
In the US, the convention is to use the term "Sensitivity" synonymously
with "Voltage Sensitivity." This is what I was advocating. However, in
Europe the tendency is to be more rigorously correct, avoiding the use
of the term "Sensitivity" by itself, in favor of "Voltage Sensitivity" or
"Power Sensitivity." In any case, Sensitivity implies the input is a
reference with a dimension such as voltage or power, while the output
is expressed as Sound Pressure Level, (dBspl).
In contrast, Efficiency is a dimensionless ratio, correctly stated as a
percentage. It is incorrect to us the term "Efficiency" if one is listing
an SPL output for a given input, even if the input is referenced to power.
In this case, what is actually being stated is simply the "Power Sensitivity."
Therefore, I retract my previous definition equating sensitivity only to
voltage and efficiency only to power. I replace it with:
1- Efficiency refers only to power, and is a dimensionless ratio.
2- Efficiency can never be stated using SPL, Volts, Ohms,
or any other dimension.
3- If an input and/or output dimension is stated, then the term
Sensitivity applies; either Voltage or Power Sensitivity,
as the case may be.
4- If the term "Sensitivity" is used alone, it is taken to mean Voltage
Sensitivity.
Some quotations:
"...What is important, therefore, is not efficiency but sensitivity
defined as the sound-pressure level produced by a loudspeaker at lm
by an input voltage of 2.83V..."
Atkinson in AES
"The overall sensitivity is defined as the ratio of the reproducer
output voltage to the recorder input voltage, at some specified
reference frequency."
McKnight in AES
"Sensitivity is a measure of a speaker's output volume level for every
volt of input..."
Ward in Sound on Sound
We now return me to my regularly scheduled life.
-k
as the case may be.
Sensitivity.
Some quotations:
Atkinson in AES
McKnight in AES
volt of input..."
-k
