adnick
Addicted Member
What size are those simpsons?
About 4.5 x 4.5 inches…..
VR
Andy
Thanks for getting back to me.I have the exact same ones with lights.Could you tell me how you hooked yours up and what is needed?There's some driver boards on Amazon I was thinking of getting that has the option for meter lights.mine came from a old mccurdy studio console that I plan on repurposing part of it for a build using the meters and possibly adding some led ones and possibly a spectrum eq.About 4.5 x 4.5 inches…..
VR
Andy
Here's what I have to work with.Thanks for
No problem, have another set that doesn’t have lights, and consider using LED lighting for them , that’s simple (comparatively)Thanks for getting back to me.I have the exact same ones with lights.Could you tell me how you hooked yours up and what is needed?There's some driver boards on Amazon I was thinking of getting that has the option for meter lights.mine came from a old mccurdy studio console that I plan on repurposing part of it for a build using the meters and possibly adding some led ones and possibly a spectrum eq.
Thanks1.DId you use a driver board ?
2.Are they connected to the output transformer or line level?
Just trying to figure out what I need to get it started.
I plan to start my own thread once I get things figured out on what I'm actually going to do .At the minimum is just getting the meters going.As for adding other led vu meters and a possible vcd display That can come later on .lord knows I have enough room on the panel.
By the way that is one sweet 300b Amp.Love the old meter as well.
Don’t recall for sure believe they are 6 volt, but you can measure across the connectors to determine for sure….someone else probably knows for certainQuick question ,What is the voltage of the bulbs and type?
I do believe your right as I came across a post on another forum saying they are 6v and either #46 or #47.In either case there are led replacements for either one now which I plan to replace them with .Since the power supply I'm going to use for the driver board is 12v I will be getting a down conver from 12v to 5 volts which should work fine.Don’t recall for sure believe they are 6 volt, but you can measure across the connectors to determine for sure….someone else probably knows for certain![]()
I have the meters already as posted above.Theyre 4 and 5/8 w by 4 and 1/2 tall which will be easy to see from my listening position even with my poor eyesight.I ordered a board today along with a enclosure from Amazon .The board won be here untill the 27th at the latest but the case will be here friday.i also ordered some rca panel jacks .Still have to get a 12 Volt power supply to mount inside as I don't want to use a laptop one . I will be posting a separate thread on it once I get everything all together.Maybe buy the VU meters you would like and buy just the VU meter driver boards? The driver board kits aren't very expensive.
