zenarrrow
Well-Known Member
I will make this as simple as I can. First off had 2 very marred covers, I had been waiting for a while and did research here on the forum of how to do it. I work night shifts and had a few slow shifts so I had time to bring them with me. I decided on using Novus plastic Products.
Here is a picture of the Marantz dust cover, as you can see multiple scratches from years of storage in a garage I suspect. Also there are several very deep scratches.
First I got an All purpose Hand Pad
Aluminum Oxide Grain Very Fine, I suppose one could use very fine sand paper or substitute a pad.
Then I attached the pad to a small Pad Sander, the nice thing about this is in fact the sander has a soft pad on the bottom to begin with. Once on I was able to put some heavy pressure and work the entire top surface of the cover. Please take note to tape over the emblem as any pressure while sanding I am sure would destroy it.
Here is a Pic of the top of the cover after nuetralizing or scouring off all scratches to make them all equal in depth. I would use glass cleaner to wipe away any debris and dust.
Again being a pad grinder it just vibrates does not spin so I was able to use force and not worry about "burning" the cover.
Next time to bust out the Novus.
Started off with Novus 3 Deep Scratch remover
I applied the Novus just with a soft clean rag. No need to really rub it in to hard using elbow grease. Just apply the Polish evenly.
Then I removed the hand pad from the pad grinder and put on a clean fresh rag. And went to work using the pad grinder in circular motion, again applying plenty of pressure.
After a thorough buffing with #3 Then I used #2 finer scratch remover. Again applying the cleaner then using the pad grinder to buffer it out.
As you can see the cover after #3 is still very dull but not quite as hazy as it was before. I can only add 10 photo's so I will finish with photo's in a reply. Please note emblem is taped. Also, a very deep defect in the dust cover off to the right of the tape.
I repeated these steps a few times to finally get the cover to a fine gloss.
