Contrary to yours, my experience with these units is that they in fact run quite warm, and run the output tubes rather hot as well. Today, if using the Russian tubes in the cathode string, they tend to not pull quite as much current for a given voltage applied to the heater, which in turn lets the unit run somewhat cooler at the prescribed bias point. But most typically, tubes manufactured in the 60s will cause the unit to run pretty hot when biased correctly.
At the very least, I have always recommended installing a small power supply to not only power the small signal tube heaters, but also convert the output stage to fixed bias operation. This effort is fairly involved, but will typically up the real power level of the unit by nearly 50% (producing about 27 watts RMS at 1 kHz with both channels driven). If you add EFB(tm) into the mix, then the unit is basically capable of 35 watts RMS per channel under the same conditions. Beside the huge payoff in tube life, the unit runs much cooler than stock, and distortion drops significantly as well. This was the subject (in part) of my thread on the X-101C, of which this thread became a part of.
I believe that Audiodon may still have the unit that was the subject of this thread, so he may be able to comment more about it since he would have had it for quite some time now.
Dave
