A totally tubular afternoon....................
dread31
Addicted Member
Beautiful day to set up outside, open all of the windows, crank tunes and test tubes on the patio.......The things we geeks do for fun.:D
Finally borrowed a tube tester from a co-worker of mine and started going through the inventory.
Unfortunately, I still could not test the 6LQ6 or 6GF7 and 6GF7a tubes I acquired a couple weeks ago. Although they all appear to be in great shape.
I did find some interesting tubes in my stash that all tested good, however.
Lots of 6BQ5s;
1-RCA (USA)
1-United Electron (USA)
4-Realistic Gold Pins, Print not so good, but mostly readable. There is a slight brownish smokiness to the glass. I believe these are Japanese. But, they have some weight to them and appear to be nice, high quality. Anyone have more info on these guys?
2-NEC-Unremarkable, but in excellent shape.
Everyone of these 6BQ5s tested above 95%, two of the Realistics @ 98%.
Also found,
2-RCA-7025 (USA)
2-Sylvania-7025 (USA)
1-GE-12AX7 (USA)
1-Sylvania-12AX7 (USA)
2-NEC-12AD7 (Japan)
All tested 80% and higher.
As I understand it, the 7025 was a low noise, more rugged version of the 12AX7. Has anyone here run them in place of a 12AX7?
Lastly,
1-Telefunken EZ80-Telefunken logo gone, but "EZ80" designation still visible. Tests good at 79%.
1-Mystery tube, that appears to be a Telefunken with the "Diamond Base"- The number "20" inside the diamond. Also appears to be a rectifier. All of the print is gone.(See attached photos.)
Dave
It's the same height as the EZ80, but, the guts look slightly different. Probably just a variation of the same beast.
Could possibly be an EZ82. Less common, but sometimes you still find one here and there. Both the EZ80 and EZ82 cross-reference to the 6V4, so they're essentially the "same"...
That said- I'd guess it may just be a production variation of the EZ80... depending on what year they were made, the internal structure can have "cosmetic" differences...
Regards,
Gordon.
