EndlessMike
So, after catching the re-cap bug from doing my Onkyo A-7070 (holy crap, what an improvement!), next on the surgery table is my Technics SA-202. The Technics, though, has a tuner section, and that is where my trepidation begins.
I have heard conflicting reports that replacing caps in tuner sections can lead to mis-alignment. Thoughts?
Also, perhaps the more pressing issue is this: several of the actual caps in the unit (mainly in the tuner section) are running different voltages than are specified in the service manual. The capacitance values are the same, but there are a lot of "50V specified - 16V found" instances, etc.
Now, in the power and other sections, I plan on always defaulting to the higher voltage value, just on general principal. However, would the chance of misalignment be greater if I follow the same strategy for the tuner stage? Would it be better to ABSOLUTELY stick to the capacitor voltage ratings found in the unit for the tuner stage? (...even against my Tim Taylor "more power!!" tendencies)
These questions are meant to be more about general practice with tuner stage re-capping than about my particular model, but any specifics are certainly appreciated.
Thanks in advance, you all are awesome. (my apologies if this should've been posted in the Solid State forum)
A few notes
Thanks again!!
A few notes
- Naturally, I'm only replacing electrolytics (and some of them look really bad). I generally stick with Nichicon audio caps UFW and above.
- I've sent the service manual to the database, and to hifiengine.com, so it should be freely available soon.
- I can also scan my notes marking which caps deviate from the service manual, if necessary.
- I can take pictures, if necessary.
- This is the first time I'll be replacing the lower capacitance components with foil caps. Any recommendations for brand/series on foil capacitors?
- There are no notes about Low Leakage caps in the service manual, but I've read that old orange colored electrolytics were LL, so I'm planning on replacing these with foils, or Nichicon UKL series. Anything wrong with that?
- I'm not interested in having the "if it ain't broke, don't fix it" argument. Thanks, but no thanks. I'm here to tinker and putz around, and any sunk costs into this project will be considered educational tuition.
Thanks again!!
