Ok so I'm trying to mark the non polarized plug on my TU-717 for lowest voltage by measuring AC on chassis to outlet ground. I've removed all the connections except the power, put my DMM on the 500 setting with AC (V~ with wavy line, right?), put the red probe on a chasis screw, the black probe on the center screw to wall outlet and /or inside the ground at the wall outlet (scary!) and NO reading. Also tried reversing the plug, and putting DMM setting at 200 V~ (only other one I have ) no luck there either. I've isolated the transformer with rubber grommets already so I don't know if that would make a difference, but I'm stumped. Oh , yes and I did have the tuner powered up.
