Only way I know of to gain complete access to the pots and switches, is to remove the knobs on the front, remove the front fascia panel, remove the bottom. Most all of the pot's and switches are on the AF UNIT which has to come out enough to gain access to them. Undo the nuts and screws on the front sub panel holding the pots and switches to it. Loosen the wiring to the board from the wiring looms (DO NOT UNDER ANY CIRCUMSTANCES UNWRAP ANY WIRES FROM PINS.) to gain some slack for moving the board. Move the board toward the back of the unit and flip up to gain access to the pots and switches.
No need to mess with the dial/string/etc. The sub panel stays secure to the frame.
