tubino
A guy with too many tubes
By the way, Rick's crossovers started with some criticism from me also!!!
Well, the truth is that mine started by trying to copy the layout used by spkrman57 when he built a pair for someone else! Except I was using larger coils on a slightly smaller board... so I had to do it differently... and yeah, Ron had some good ideas. And that's after pointing out my goofs.
I'm happy with the path lengths. Without getting the inductors closer together (= bad), the only way I see to make paths much shorter (while keeping input and outputs at the back and Lpad at the front) would be to rotate the L-pad 180 degrees and I don't think it's worth the hassle.
Ron S, it's been playing all day in the workshop, and sounding pretty good despite the new components. The much sharper roll-off on the 2226 is immediately noticeable when I turn off the horn. I'll go check on it tonight to see what's happening, but I was enjoying it quite a lot earlier today.
Ron C, I don't know how much is in yours, but this one is 3rd order and 3rd order with a zobel (cap and resistor) and EQ (cap and resistor) One reason I used so many of those little blue mini-strips is so that I could switch out caps later to compare Solen etc. I don't know if I'll do it, but I was thinking... I've got another pair of 2.7mH coils, pair of Lpads, and lots of resistors, term strips, and big oil caps. For the price of 4 more modest value aircoils I could replicate these BUT use all oil caps instead of polypro film. Maybe I would hate the sound, but it would be pretty easy to find out for sure. I'd probably build them as real working crossovers with a lot of space, and to make component switching easy, about 3 times as many barrier strips as spkrman would approve of.
