This Accuphase E-202 came to me is in the protection mode when powered on. With the right amp board removed came out of protection. Check the pre-amp section separately, one channel is good but the other one had considerable distortion.
After checking the right amp I found the culprit was the differential pair. Replacing those solved the problem and for the preamp, a good cleaning of switches brings both channels into working condition.
I found someone in there before me and replaced one main filter capacitor, one resistor in the power supply.
Now it is ready for restoration.
First is the power supply board
What has been replaced:
Q1,Q2,Q5 - 2SC1451 - KSC3503DSTU
Q3,Q4 - 2SC1746 - KSC1845FTA
Q6 - 2SA497 - KSA1220AYS
Q7 - 2SC1746 - KSC1845FTA
Q8 - 2SC497 - KSC2690AYS
Q9 - 2SC1382 - 2N4923G
Q10 - 2SA682 - 2N4920G
Q11 - 2SA856 - KSC992FTA
D1,2,3,4,5,13 - 1S1555 - 1N4148
D11,12 - SV-02 - 2X1N4148 in sereis
Heat stressed R7, 27, and 28 were replaced with the same value and higher wattage metal oxide resistors.
C1 - 100uF/10 - 100uf/25V (Bi-polar Axial Vihsay)
C2 - 10uF/25 - 10uF/35V (Elna Silmic II)
C4 - 100uF/63 - 100uF/100V (Axial Vishay)
C5 - 3.3uF/50 - 3.3uF/50 (Bi-polar Nichicon muse)
C6 - 2.2uF/50 - 2.2uF/50 (Bi-polar Nichicon muse)
C8 - 2.2uF/50 - 2.2uF/100 (Panasonic ECQ)
C13,14,15 - 100uF/100 100uF/100V (Axial Vishay)
C16,17 - 10uF/80 - 10uF/80 (Axial Vishay)
C19- 4.7uF/50 - 4.7uF/50 (Bi-polar Nichicon muse)
C23 - 1uF/63 - 1uF/100 (Panasonic ECQ)
Before:
After
Before:
After
