dc270
Now Off the Reservation
I ask another question about modifications for my 1980 Cornwalls. Has anyone experimented on the front baffle by installing acoustice foam/ "blanket", say 1/2 thick or less, around the horn openings? This would act as a difraction blanket like AR uses on the AR9's. The therory sounds valid in practice for cone/dome drivers, just not sure for horn lens openings.
Another modification of mention for my CW's. I cut a rectangular hole on the back baffle, 2.5" x 3.5", centered, where the original connection area used to be. I put a .75" thick wood plate inside overe the cut out area with about an 1" over. I then installed two HD binding posts of gold color. This akes me feel better than just about anything else! Nothing alarms me more than to think of a wire dropping loose during a loud session.....I can sleep now!
I have the toe boards un-screwed from the bottoms and the loose veneer being glued back into place. So,e how the previous owned got these wet and they partially split. Soon as they are sanded and re-painted back to a new look then I will be screwing on each retangle, four, 2" HD, black carpet rollers. A big speaker that is easy to move is a big plus for me and y wife who like to clean under everything!
DC
DC
