Rome
Holsum Honey Buns
More power is better with these pups.
I drove mine very happily with a Marantz 2325.
Hi Pbda!
Thanks so much for the info.
Rome
Yea GK!
Since these speaks have a sentimental value attached to them I probably will not let them do heavy duty in my system. The Polks are more than up to the task for that. I will use the AR's for a lighter duty. Just want to enjoy the sound others rave about on the speaks! :yes:
Thanks,
Rome
have doubts...:scratch2:
LUXMAN C-02 PRE AMPLIFIER with M-02 POWER AMPLIFIER.
or sansui 7070 ?
with my Acoustic Research AR-3a... :thmbsp:
Back in the early 70's, when I bought my first pair of AR-3a's I drove them with a Sansui 5000x and thought they sounded fine (50 or so wpc @ 8 ohms - not sure at 4 ohms)
I have my current 3a's paired up with a Marantz 2285b and they sound superb!
Sometime soon - I want to see what the 3a's will do with a bit more power - my Marantz 2385.
Thanks guys!
I plan on connecting them to my Kenwood KA-995 (100wpc) a/v amp soon. The only thing is I am not sure if it will handle a 4ohm load.
Rome
My amp is 55wpc @ 4 ohms and it works just fine with my 3a. Had another amp that does 115wpc @ 4 ohms and couldn't tell the difference myself. I guess it's got to do with the room size too. I'd worry more about the distance as Terry said rather than the wpc.
I seem to recall you said you preferred the Allison over the 3a. Has that changed with the new amp?
Classic era AR's were designed to be "bookshelf speakers." Their optimum height is 12-36" up off the floor, and most of them were intended to be placed horizontally.
It's a shame, in a way, that "bookshelf" has stuck to a size of speaker and where it's "supposed" to be placed. Bookselves were "all the craze" years ago, let's face it, no computers (till late 70's), no game machines, so people were outside, or watching TV or reading. What better way to "fit" you're system than a bookshelf desgin? And it didn't end with just speakers. Check the ads back "in the day" and you will find many amps and receivers advertised as being shallow enough to fit in a bookshelf.Actually, that makes a lot of sense (The height part, not the bookshelf thing). My Wharfedales have a similar design..... 12" 3-ways, non-mirror-imaged (except for the power-hungry woofer), and you really-have to get them off the floor (18" or so) or at the very-least tilt them back a bit so the tweeters are pointing at the listener's head.
Sadly it seems that being a "bookshelf" speaker means that is the only place it will sound "right". Depends on the type of bookshelf. Depends on whether the speaker is sealed, front ported or rear ported. Does the bookself have a back, is it open, is it close or away from the wall?
