Ficklistnr
Passive Fanatic
I've been sitting on a pair of Acoustic Research AR2a speakers that are in very good shape making them excellent candidates for a thourough restoration project. With no variations planned outside the original build specs.
However, I recently discovered something that struck me as quite unusual. I may just be confused by assumptions and misinformation but it has been my understanding that all AR2a cabinets while having several options of finish laminates ie: utility pine, unfinished walnut etc. The cabinets were all constructed of the same base material MDF panels on top bottom sides and front (baffle) with a plywood back found in earlier manufactured pairs, replaced with MDF in higher number series completely eliminating the use of plywood anywhere in the cabinet.
This obviously does t fit with what I have in front of me .
They are in fact factory cabinets with the original AR informational printed on paper and affixed at each corner with a single staple.
The baffle on each is in fact MDF however, each of the 5 remaining panels are 5 ply with no finish grade laminates. The back appears to be a lesser grade finish ply.
Does anyone have an explanaition for this? Am I mistaken or misinformed with my assumption that the AR2a had never been manufactured with an all-plywood enclosure?
Might I be in possession of a demo or customer requested special order? Or is it possible this set was built to compare and demostrate the accoustical differences between the two materials. It's my understanding that the use of MDF vs plywood was a hotbed topic in this era. I'm curious if earlier AR models were built with all plywood/MDF baffle cabinet material. And of course if an all MDF cabinet had been commonly found with a plywood back and an MDF back.
I have little doubt the cabinets in front of me were produced by AR and are not likely to be a post-sale modification.
All elements of design and construction are identical to that of an all MDF cabinet AR2a.
Ill add photos during daylight hours.
Thanks for any input and references in advance.
