Acquired: Paradigm Studio Monitors
FriedChicken
Ever since I regrettably sold my old paradigms (monitor 9's) I've been in a sad state chasing down that glorious audio that I had.
I got the monitor 11's of the same generation, but they just lacked bass. Higher clarity, less room-filling capability. Then I got Polk Audio RTi A9's that had the bass that I sought, but everything else about them was a step down. In between I had some other newer pardigm's (I don't even know the model). Tiny little things that lacked that room-filling bass crescendo punch.
I just sold those, a few days ago, and now I have what might be the answer: a pair of Studio Monitor's.
I measured with the LCR meter, and the impedance across the different frequencies matches very well.
A visual inspection shows the tweeters needed new ferrofluid.... a decade ago:
Listening shows... incredible imaging. Just incredible. I placed them somewhat haphazardly in the room, but the imaging just fell right into place. Voice separation is also really good. The cabinets feel solid. The surrounds for the woofers are supple. There is no crackling....
The midbass seems... kind of unclear? The Monitor 9's I had felt "tight", solid, and confident. I suspect these need serious cranking, and I cannot do that immediately tonight.
Beyond the tweeters, I'm debating upgrading the now 30-year-old capacitors in the crossovers.
We'll see, I hope these can match the monitor's that I regrettably sold
Access to the crossovers happens not through the rear, but through the front. Forget through-hole, forget surface mounted device, glue onto hardboard seems to have been Paradigm's way in the late 80s.
The padding material seems to have shifted/moved around, and it's.. wool? I don't think it's synthetic, and it has a pleasant smell and feel. I hope it is not asbestos.
Looks like only a couple caps in the lower right appear to be electrolytics that might need replacement. All the others I can see appear to be film caps.
Also, FWIW, there is a difference between the Monitor series and Studio series.
There is another "board" (literal hardboard) of stuff underneath the center one (where the binding posts attach), and it has its own electrolytic capacitors.
These speakers are the "Studio Monitors". That is what they are called.
From the comments on that 2nd article/review:
Bluestreaks58 said:
These belong to the original “top of the line” Monitor Series which was a step up from the Performance Series.
The Reference Series was introduced replacing the Monitor Series. A couple of years later, the Monitor Series was re-introduced, replacing the Performance Series.
Predecessors to the Studio/100s I have then?
