I made some very good progress this week and was able to finish turning the last two of my acylic platters. I decided to do these at the same time in case I screwed one of them up like I did on the first one.
I left this one at 3/4" and didn't mill the top or the bottom surfaces. I chamfered about a 1/16" relief for the record label and chamfered the outer edge about a 1/4 x 1/8". I think this looks a lot better and gives a slight relief for the run-in groove. I had to make a special tool for turning the groove on the underside of the platter for the lip on top inside edge of the platter.
I am very happy with how everything turned out. I was thinking about blasting it to give it the satin finish you see on most acrylic platters but I think I like it the way it is. I may experiment on the first one and see how it looks and then decide from there if I want to do it to this one.
The only other thing left is the centering spindle for the record. I ordered stainless round to make a longer spindle but I am thinking of getting some acrylic round and gluing it into the top of the platter. There is about a 1/4" or room from the top of the platter to the top of the spindle. That should be plenty of room to glue a short stub for centering the records on.
I think it actually sounds better now than the first platter I tried with the rubber mat. I can definitely turn it up more now before I get feedback from the speakers. The music seems to have better clarity to it also than before. The only other thing is to make a new thrust washer. I had some teflon round around here somewhere that I had ordered for my PL-61 but couldn't find it. This one is slightly larger so I ordered a new piece. This should bring the whole platter up some more as it's riding a little low from the bad original thrust washer.
I have to say I'm VERY happy with the results. If anyone is up in the air about what kind of platter mat to try I would definitely recommend trying an acylic mat. I can't guarantee that you will get the same results but it's worth a try. And here are a few pictures for your enjoyment.
View attachment 250028 View attachment 250029
View attachment 250030 View attachment 250031
