dnewma04
The Healer
I have an "Aspen" brand acoustic guitar, it's labeled an AD-25, which I'll assume is a Martin D-25 clone from Japan, although, this may have preceded the D-25. Which might make it a Guild D-25 clone. In any case, I'm a total guitar noob and as far as I know, it's a dreadnought with a mahogany body and spruce top.
I had it set up at one point which helped the action, but over time, it's raised. I noticed that behind the bridge, the body has raised up, when removing the strings it flattens right back out. When I got it, it had steel strings on it but in a recent thread, someone mentioned that some acoustics meant for nylon strings will exhibit this behavior when outfitted with steel strings.
Any thoughts about whether I should swap to nylon strings and if so, does anyone have recommendations? Are there other things I might be able to do? I notice that inside the body, it doesn't have the allen head adjustment that some other acoustics do.
From what I've read about the brand, they made decent quality guitars and it's in pristine shape, so i'd like to keep it if it's a simple correction.
