pioneer07
Member
I recently spotted one of these vintage graphic equalizers for free on Facebook Marketplace and I grabbed it. It powers on and all of the lights work. It has a button called "EQ" which turns the equalizer function on and off. When it's off the signal just passes through, but you can still watch the lines dance. When the EQ button is on, I only get the left channel and no right channel, and no lights on the right side. I have been searching for a schematic or service manual but I haven't been able to find one. Anyone know where I might locate one?
Yes, I am going to dig in to this and check for dry solder joints (seemingly a common problem on similar ADC equalizers in other forums I read). I'll also clean all the switches, but a schematic or something would sure be nice. I do plan to re-cap it. I am pretty confident I'll be able to restore the right channel but if anyone has run into a similar issue and one of these routine services didn't fix it, I'd be curious what it was. I have a scope if we need to go there but, again, that's where that schematic sure would be handy.
Last thing - a page I found about a similar ADC mentioned upgrading the op amps. The op amps in this one are 2 of the JRC4558D. I searched for replacements for this JRC4458D and the ones being mentioned elsewhere were the NE5532 and the TL072. The applications in those discussions were different than this though. I'm kind of clueless about these things other than the little bit I read. I'm curious if upgrading these op amps is worth the trouble or risk. The other pages I read said the JRC4458D was OK in its time but has been far surpassed since then.
