Hi all-
I just picked up a used GFA-5400, and am checking the bias adjustment. In the service manual it says:
"Prior to performing BIAS ALIGNMENT and DC OFFSET CHECK turn unit on and allow to run with rated output for approximately 5 MINUTES before attempting adjustments"
Does this mean to run the amp at full output power for 5 minutes? I'd have to get a wattage meter (or calculate the voltage across the 8 ohm power resistors on the speaker terminals).
Also, most amps I've set up I usually short the input jacks, this one says to have an input resistance of a certain value or less. Is this just putting resistors across the input jacks?
I'm a bit confused, and I want to set the bias correctly. Anyone have this amp, or similar and done this procedure?
Thanks
Glenn
Thanks
Glenn
