Seems to be a lot of misinformation on these amps on the web. I've had this amp for a few weeks and haven't done much with it but did do the research. A few things folks will learn about the GFA-555;
The GFA-555 had both the rack mount faceplate with handles and the extruded faceplate with the ribs. I do not know if this indicates a time of manufacture. There is also a GFA-555 Pro with front panel circuit breakers for the rail fuses and it is a rack mount unit. Here is
@hjames thread about the different physical versions of the amps.
http://www.audiokarma.org/forums/index.php?threads/adcom-gfa-555-variations.272875/
The GFA-555 was manufactured with two different input boards. One mounts vertically on the center rear panel on standoffs and has a small board with the RCA jacks under it. The other board mounts horizontally at about the level of the RCA jacks. These are different and there are different schematics associated with them. More anon.
This original version is the one that was designed by Nelson Pass and it seems he didn't want protection circuits degrading the sound of the amp. This can be a problem if the amp dies while in use and takes out your speakers but there seems to be a large group of owners that have never had a problem with their unit.
The GFA-555 II is similar in looks but different in execution has its own issues and servo control to keep DC offset in check. This discussion is not about the II but its issues do cloud the GFA-555 reputation. One issue in the II is the leaking caps that contaminate the input board causing problems. This is not an issue with the better boards of the earlier amps, to the best of my knowledge. The leaking electrolyte would permeate the paper circuit board and it would affect the electrical characteristics of the II amp.
The vertical input board schematic is on HFE labeled
schematics.
https://www.hifiengine.com/manual_library/adcom/gfa-555.shtml
The pdf labeled
service manual has schematics for the other (horizontal) input board. It is not what I have in the vertically arranged board but I don't know much more about this one. I'd have to get one and compare it. That schematic is probably available on the web with better legibility as I think I saw it just didn't grab it. The difference is the numbering of the transistors, starting with Q1 in the horizontal board numbering and with Q601 on the vertical board. The vertical board is copyright 1986. Hope this helps some.
