Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
No worries, I figured there must be a different version out there. I think I found the right switch now. Consequently I have 2 switches for your amp if you ever need one let me know.
Wow, now that is an older version. Might have been intended more for commercial applications where looks count for nothing.
I am (intimately) familiar with what are generally known as the MKI & MKII models. I'm guessing this could be referred to as a MK0.5 model?
I ended up getting the second set of switches from Adcomparts.com They are wrong also. I tried emailing them a couple times but no reply. Either way I'm still searching for the main power switch for the aforementioned MK0.5 model. If anyone could point me in the right direction I would be grateful!
Interesting, all the rack-mount GFA-555's I've seen so far have all used the same switch as later models.
The Carling RGSCC901 used in most GFA-555's is a compact design for a 16A switch. You seem to have the more common size for this type of rocker switch. There's actually plenty to choose from! And you can get slightly higher current rating than stock, which is good because sometimes GFA-555 switches weld themselves shut, due to the large in-rush surge current.
These rocker switches are a sort-of standard size. Can you measure the length and width of the cutout?
*It should be noted that the Carling RGSCC901 used in most GFA-555's is rated 15A@250 VAC and 20A@125 VAC, while the NKK JWL is rated 16A@250 VAC and also 16A@125 VAC. The slightly lower rating of the NKK at 125 VAC is not cause for concern IMO. They could have up-rated that spec at the lower voltage. These are very similar switches. The NKK is specifically advertised as "High-Inrush".
And ugh, I just noticed the NKK has 3/16" fast-connnect terminals and not 1/4", so you'd have to install new terminals. Maybe you can find another switch with the right terminals.
