When I 1st bought my 5802 I contacted adcom about the speaker outputs because they were labeled NORMAL & BI-WIRE. I was told by someone at adcom to look at it like A & B speaker outputs on other amps & that the BI-WIRE outputs could be used to drive an additional pair of speakers just like the NORMAL outputs.
But.... If a pair of 8 OHM speakers are connected to the NORMAL outputs AND a second pair of 8 OHM speakers are connected to the BI-WIRE outputs does that result in a 4 OHM LOAD on the amp? Are the 5802's NORMAL & BI-WIRE circuits wired in parallel?
Assuming the above is true, then I've been driving my 4 cornerhorns with 450 watts / ch, roughly 112 watts / speaker, which is OK but a little hard on the amp Correct?
Is there any way to connect four 8 OHM speakers to the 5802 that results in an 8 OHM load on the amp?
If I connect four 8 OHM speakers in series to only the NORMAL outputs (Amp Left (+) terminal to Speaker 1 (+), jumper wire from Speaker 1 (-) to Speaker 2 (+), from Speaker 2 (-) back to the Amp Left (-) that will result in a 16 OHM load on the amp, Correct?
