Greetings AK,
Thought I'd share a quick project I started and finished today. I decided to add some binding posts to my Sansui Six by removing one bank of wire terminals and replacing it with binding posts screwed into a sheet of Lexan. I live in a college dorm, so I don't have any power tools except a drill; Lexan is great because it can be cut with aviation shears. It's also highly resistant to splitting when drilled. If the holes are drilled small enough the screws will self-tap and there's no need to use washers. Anyways, here are some pictures:
Before:
Lexan after drilling:
Wiring:
The result:
Before:
Wiring:
The result:
