kahlfin1k
Well-Known Member
So I've done some reading on this and think I have it right but wanted to get a second opinion from all you experts!
It seems a safe way to do this would be to use an L-pad to maintain an 8 ohm load on the OPT and a voltage divider in series with the phones for attenuation. The only thing that confuses me is if I should tailor it exactly to my headphones nominal impedance (Grado SR225i at 32ohms) or a standard 120 ohm output impedance. Advantages/disadvantages? I used this calculator http://www.nu9n.com/tpad-calculator.html. to come to the values in the attached diagram which would give me 20 dB attenuation. I might end up trying different impedances/attenuation but is this concept the right idea? Any reason this is a bad idea or other parts of my amps design to consider such as NFB which comes off the 8 ohm tap also (included in diagram)? Obviously there's a switch in there too. Was thinking a 6 amp mini dual toggle. I know noise can be a large consideration for headphone amps too but this amp has no audible hum or noise so I'm not too worried about that!
Thanks!
Thanks!
