cpt_paranoia
Addicted Member
how to I force the KEiiD to use ethernet for input and not the WiFi I configured?
IIRC from the Keiid thread, by doing a power cycle with ethernet connected.
What is the reading using the USB input? The optical input is limited to 44.1/16. I am not sure about the coaxial input.
USB is inherently a noisier signal path than coaxial or optical
Don't send it back.
According to What Hi-fi, coax digital is good for 24 bit/192 khz hi res files. Optical is good to 24 bit/ 96 khz. That's assuming your sorce provides it.
My Denon 1920 SACD/DVD player outputs 192 khz through it digital outputs, at least the coax as it has no USB connection.
But I must be limiting it somewhere!
I saw that quote - where/who is it from?I think the problem lies with the Keiid player's optical output. See post #14 in this thread. It seems to me that the problem is with the Keiid player and not the DAC.
It was a question on Amazon's website whether it can play 192/24 The answer was from Keiid.
Hopefully you will get an answer to your email soon...
pi@raspberrypi:~ $ cat /proc/asound/S3/pcm0p/sub0/hw_params
access: MMAP_INTERLEAVED
format: S32_LE
subformat: STD
channels: 2
rate: 192000 (192000/1)
period_size: 7680
buffer_size: 30720
Answer: Hi, Usually, our optical port can only support 44 KHz 16 bit files, if you want to stream 192 KHz files, it will play them at a lower rate and the sound will be different from the original files.
