James,
A Zobel network is designed to create a constant impedance (primarily resistive) load in a reactive network. Your woofers, with their large motors represent a highly inductive load - so the Zobel network was added to make the woofer appear as though it is a resistive load - and not reactive (inductive).
From the top; voltage and current in ANY electrical system are not always "in phase". This means that you can have high voltage and no current or high current and no voltage. This difference between the voltage and current phase is referred to as "power factor". These two values, voltage and current become out of phase when the electrical flow encounters reactive elements (capacitors and inductors). Your crossover network is by definition highly reactive.
To make the situation even more difficult the speaker motors themselves (big windings) are also reactive (primarily inductive). So given the large motor on your woofers the Zobel was added to adjust the power factor of the incoming audio signal so that whatever power is being pushed to your speaker has a unity power factor (voltage and current completely in phase). Thus making your crossover and motor network more efficient.
Therefore adding a Zobel to the mid-range elements of your crossover will NOT make the mid-range "less" pronounced - if anything the mid-range will get LOUDER - for the power factor should be, if you design your Zobel correctly, enhanced and therefore pass a more powerful signal to that driver.
Do not add a Zobel to your network. That will not serve your purpose (which seems to be to attenuate the mid-range signal). My suggestion is that the only way you can lower your mid-range signal is to add a "real", i.e. a resistor of some value (I would go higher than 10 watt capability by the way - if nothing else parallel the two 10 watt resistors). Look for around one or two ohms to start your experiment.
Or you can be cute - as I have done myself - and add a lower than sufficient resistor thereby creating a volume dependent load, i.e. the resistor will heat as you increase the signal and the resistance will therefore INCREASE - so you will load the signal more heavily at higher volumes. Works quite well with the one caveat that you may burn out the resistor at a ridiculously high volume (ceramic resistors simply crack when heated too much - and the resistance then goes to infinity or "open circuit").
Let me know if this helps or you need more advice.
Thanks Reddog, that helps. The thing is that my goal is twofold+. My ears are telling me that my mids aren't just a bit too loud, but I feel that they are getting a bit too much into the high range. I realize that that is more properly addressed by adjusting the crossover point, but had hoped that by flatening their inductance curve that I might be able to avoid making any changes to the crossover point, something that I would rather avoid with my non-skills in that regard. Then I could address the mids loudness as a second step with padding. And when I ordered the zobel parts I also ordered some 1.8, and 1.0 ohm 10 watt MOXs also, so that I would be prepared if that is necessary. Is that really taking the wrong path?
Let me ask this: After I replace my 10" woofers I had been thinking about replacing the iron core inductors in the woofer section of the crossover with some air core coils that have less DCR. The stock inductors measured out at 3.4mH and 0.9 ohms. I had hoped that by lowering the DCR on the woofers inductors it would raise their efficiency, and then I wouldn't need to pad the mids as much, if at all. Is there any sense to that, or am I trying to think too much.
James
