Adjustable VTA on SL 1600?
Sticklyman
Well-Known Member
Greetings,
Does anybody know of a way to adjust VTA on a Technics SL 1600? I've got some sheets of cork that I want to try as a mat, but they are thicker than the original. I didn't see anything about VTA in the manual, but I figured I'd ask just to make sure.
IIRC there is not an adjustment on the tonearm itself so you will have to shim the headshell.
I have a SL-1700 and found the arm was higher than I wanted so I put an old album "under" the rubber mat of the right thickness, worked like a charm and I think it improved the sound as well. The top of my Grado Gold now rides level as per Grado's recommendation.
Yep your gonna have to use different mat thickness. Not to hard to makem either after your first 25:D
I know that's what I had to do on my 1500........
I suppose I should have looked beforehand to see how my cartridge wants to ride on the record. As it happens, I need a bit of a thicker mat, lucky me. Now I just need to figure out how the hell I'm going to cut that cork to fit and not balls it up too terribly. Any advice?
I just laid my plastic mat (Technics stock) on top of the cork and carefully used an exacto around the circle. I did a little light sanding to even out a few bumps. Use a drill bit for the spindle hole and you're set. The cork usually comes in a 4-pack so you should be set (even with mistakes). I have thumbs for fingers and I did it. You can too!
Thanks man, I hadn't thought of that.
