Adjusting Anode Dissipation in Class A1
P78
AK Subscriber
If this has been covered, please direct me to the post!
I am under the impression that the Tung Sol 6550 Reissues that I am using in my Altec A340-A are running at around 90% anode dissipation. Admittedly, I have calculated this by including the screen grid dissipation by measuring anode to cathode voltage and dividing this by the anode current as measured by matched 1 Ohm resistors (connected from pin 8 of each 6550 to the common cathode resistor). This amplifier is designed to run Class A1.
As these newer 6550s had a different bias point than GE 6550s, I had to increase the cathode resistor (R17) to an adjustable 250 Ohm unit from the original 150. I had set this adjustable resistor at 217 Ohms for a cathode current of 78 mA. I recently tried other resistances without being able to reduce the dissipation. (The worst was putting it at 156 Ohms, which led to a dissipation of over 37.5 Watts and cathode current of an impressive 96 mA each 6550.)
Burning question is whether there is a way to reduce the plate dissipation or am I assuming that the 35 Watt dissipation design maximum ratings that I am seeing in the Sylvania Technical Manual (and the Brimar No 9 under the 7D11) are understating it? I had seen some mention a 42 Watt anode dissipation in this forum, and the Brimar manual mentions a combined screen and anode dissipation of 40 Watts. If 42 Watts, the dissipation is around 75%, but the amplifier, being class A1, does run hot. (It's the only one I have. Everything else is AB1, so an operational comparison is not possible.)
According to the schematics it is a pentode design. Thus you can reduce the g2 voltage and get the same effect
as with a changed bias.
A simple method is to have a 10V zener in series with the existing g2 supply, this reduces g2 voltges by 10 volt.
Alternativly a transistor based stab circuit that could be made adjustable could be an option.
Change g2 will not lose power as much as increasing cathode resistor will do.
just a mention on the dissipation thing, they aren't actually different per-brand, its just different rating systems. The Tung-Sol and GE sheets are design max and specify 42 watts. The RCA sheets are design center and specify 35 watts. Offhand I don't know what the Sylvania sheet is but it'll be one of those two. I have no idea what Brimar was using, but Euro tube rating systems are sometimes different and I honestly don't know the particulars there.
anyway, bigger cathode resistor makes for higher cathode voltage, which is in effect a more negative grid and that lowers current. So yes you can lower dissipation, but as you drop the current the power supply voltage tends to rise so that relationship isn't perfectly linear.
You could try changing the 0A3 screen dropper for a 0B3 or 0C3 to drop more voltage to the screens.
Interesting thoughts, and the revision of the regulator valve is the most appealing and easiest for me to do. (I am not that well-versed in solid state but can get by.)
I don't know what happened, but once the old GE 6550s dried up, I found that I had to change the fixed bias on other amplifiers to work with modern/current 6550s. Of course, this was well before I had better grasp of what I was doing, but I did find that if I did not readjust the bias on the Allen Organ 75s, I would have some fine examples of red-plating. (I had bought matched pairs, and once the bias was readjusted, I had years of trouble free service. Then the price jumped, but that is beyond the scope of this enquiry.)
I know I have 0C3s and will try it first, for I doubt that I have any 10 volt Zeners on hand, unless I needed them for the repair of the Tek 106. I suspect that I would need a one watt, at most, if I did get some? I guess the 0B3 would have been a better first choice, but I have never had any of those.
Thanks for the ideas! I knew there had to be a better way.
Turns out that I do have a 10 Volt Zener, a 1N4740A. Will one watt do in this application? Do I install it with the cathode band facing the screen grids? (I would not normally worry about blowing it up, but I have only one on hand, and the web didn't really specify using it in series, as peterh suggested.)
On the other hand, if it might introduce noise, I will change the 0A3 to a 0C3 or get a 0B3.
Why are you attempting to reduce dissipation? The schematic shows a 150Ω shared cathode resistor with 30V across it. Based on 390V across the tube, that works out to 200mA total and 39W dissipation per tube (anode plus screen). You measured almost the same thing with a 156Ω cathode resistor, so it seems the amplifier is operating normally.
Jack
Does this mean that I have mistakenly applied AB1 operation and the dictum that the dissipation percentage should be around 70 when it does not apply to A1 operation?
I had hoped to reduce the dissipation to prolong the life of the 6550s to answer your question, Jack.
I'll leave well enough alone, see how the amplifier runs with this set of 6550s, and try not to fix that which is unbroken in the future. (Or if I do, I will keep it to myself.)
I think you might be missing the distinction between cathode bias and grid bias. When a cathode bias amplifier like this one is operated near full output, voltage across the cathode resistor increases due to the additional current flow. This moves the amplifier toward class B. In order to prevent crossover distortion, the amplifier must be biased more heavily at idle than an amplifier using fixed grid bias. There are two solutions I'm aware of. The first of course would be to install a negative bias supply in the amplifier. This would allow you to cool off the output tubes, and in addition would result in greater output power because the cathodes would be grounded. Bias would no longer be subtracted from the available plate voltage. The second approach would be Dave Gillespie's EFB, which regulates the voltage at the cathode. This allows idle current to be reduced without the risk of crossover distortion at higher power levels.
Jack
just as an idea what the mfg has to say about class A conditions, this is single tube but push-pull class A is just this times two for current demands. Handily though, the bias is actually even more stable than it shows here since as one tube conducts more, the other conducts less. A voltmeter on the cathode should show very little change from idle to full output in a P-P class A output stage, especially if the tubes are well matched.
At 400 volts and 87 mA is 34.8 watts of plate dissipation. This is a design max datasheet so it allows 42 watts, so its running at 83% of rating. 250v has it at 35 watts, which comes out close enough to the same.
If you are going by design center values, this is basically 100% of the dissipation rating.
also just a mention, plate voltage is measured from cathode, if measured from ground you won't have an entirely accurate reading, especially if lowering the current through the output stage causes the plate voltage to climb. The cathode voltage is going up too though so there ends up being less voltage across the tube.
I will look up Gillespie's EFB but am sorely tempted to convert this to fixed bias, if only because all my other amplifiers are so configured. On the other hand, I could, and probably will, put everything back the way it was designed and run the amplifier, as hot as it seems to get.
I could take the 'Typical Operating Conditions' to the RCA nomograph to make it conform to the operating voltages of the amplifier. I write that only because of the higher screen grid and cathode voltages in my set up. (I did measure anode to cathode for all of my dissipation readings and got a range of 392 to 405 Volts, and the reading that is most germane would be when I had set the cathode resistor to 156 Ohms. The anode to cathode voltage was 392.
Stats for the output stage, per the error-prone Sam's Photofact: 420 Volts for anode, 360 Volts for screen, 30 Volts for cathode, and 4.4K Ohms for OPT primary
Yes, modern-made 6550 tubes probably won't last long in a Class "A" output at 42-watts of idle dissipation. The last of the more recent-made 6550 tubes that could handle that for any length of time were the 1990-2000s St Petersburg-made, Svetlana (=C=) 6550C.
The easiest way to lower the idle watts of dissipation is to raise the value of the cathode-tied resistor. Substitute in a 250-ohm or 300-ohm, 10-watt wire-wound resistor and measure the idle bias. You may need to go as high as 400 ohms to get to a 35-watt level.
Remember, as you increase the resistance, you start moving within the Class "A" range. The ultimate sound may change, especially as you start to fall out of Class "A." It may start losing the Class "A" warmth.
Just sayin', if I had a beautiful set of Altec amps, I would keep them the way that made them beautiful amps.
I guess so. He'll need to find some nice NOS Tung-Sol or GE 6550s. In my experience, the latest iteration of Chinese and Russian tubes is going to have a difficult time at 42-watts of idle dissipation, for any length of time.
It's the bane of all those old-time Ampeg SVT owners. :(
If I may, for the operating conditions and information given, this amplifier is very much a Class AB1 design. The reflected plate-to-plate load from the output transformer is much too low to allow it to operate under Class A conditions throughout the full power output capability of the design, which is the very definition of what a true Class A operation represents. It being a cathode biased Class AB1 design, the quiescent current is run on the high side (as is typical with such designs) to minimize power loss through the cathode resistor, and to help maintain a reasonable bias voltage when the stage shifts from Class A to Class B operation. Now granted, the stage does put out a significant amount of power in Class A before shifting to Class B (about 17 watts from quick calculations), but since the design is capable of a total power level that is about double this amount, that places the design squarely in Class AB1 territory.
Dave
You mean the Altec brochure for this and the accompanying pre-amp, their A440A lied? 1785898768826.png
It's in the first paragraph that the hype starts about this being 'an engineer-audio enthusiast's' dream and '[The 6550s] are conservatively operated at 35 watts in the classical Class A1 condition.'
As Triodeluvr and Dave Gillespie seem to recommend switching to fixed bias combined with the rather delicate nature of modern 6550s (and mine, having been made in May, 2008, would certainly qualify!), I might just do that. I have returned the cathode resistor to 150 Ohms, as originally configured, though, and just have to find the time to put it in my system along with another valve amplifier of similar power, of course.
The quiescent (no signal) current level is certainly of a level that would support Class A operation, and it no doubt puts out a good amount of power in Class A before shifting to Class B, but it does ultimately shift to Class B operation well before full power is reached. Manufacturers were fast and loose with what constitutes a Class A output stage design, but by definition, an output stage is only truly Class A if its entire power output capability is produced in that mode (neither tube is ever cut off). If you run the operating conditions and reflected load line given for the amplifier on any of the popular load line apps, the load line shift to Class B operation is plainly visible.
Dave
It’s like any one of a bazillion other Class AB1 amps out there. This one just happens to develop a fair amount of power in Class A before the shift begins due to the high quiescent current.
Dave
