So I replaced a couple of the output transistors in the L-07Ms and now its time to adjust all of the settings. In the service manual it states to put the negative probe of my DMM on the number 23 post of the power supply board and then to ground the positive probe and it should measure -63Vdc. I measure and I actually get a +63.3 Vdc. Is it the same as measuring DC offset and it does not matter if its positive or negative or does it matter in this case? I'm fairly certain there isn't enough movement in the potentiometer to swing from -63V to +63V. I'm going to hold off on any other adjustments until I get a response I guess. Thanks!
Dan
Dan
