americannigh
Seems few and far between finding classic receivers at my local Goodwill these days. They usually end up on the auction site. That said, I lucked out yesterday and paid $24.95 for my first Pioneer to add to my collection, a Pioneer SX-535. Overall condition is probably a 7 on the case. There is a bit of paint splatter on top and some de-lamination near the bottom edges of the veneer case. Maybe it served as a garage stereo at some point. But overall not a bad looker after wiping down and putting a little oil on the cabinet. The story I'm sensing from this receiver is that someone tried to work on it at one time. Those blue Sanyo caps have all been replaced with some Nichicon caps. All the lamps work and glow strong except the grain of wheat bulb for dial indicator that needs replacement. The front face of this specimen is really clean and lights up nice. It's a real looker, especially in a dim room. Control POTS all work great. Maybe someone cleaned them. The original owner's name is engraved on the back along with California. I'm guessing original 70s owner because California is abbreviated Calif. Didn't we switch to two letter state abbreviations in the mid-80s? That's my recollection anyway.
Before powering it up, I had to repair one dangerous modification someone made to this unit, however. The speaker protection fuses AND fuse holder had been removed and the outputs were hard wired to bypass that protection circuit. I installed a couple standard AGC fuse holders and 3V fuses as per the manual and schematic. Also put about an hour doing a cleaning of the electronics and close inspection. No burned components or bad looking caps that I could see. The two 4V fuses on the outputs were blown, however. Totally expected those and maybe even the 3V protect fuses I installed to blow when I powered it up. However, all powered on good and the unit sounds excellent. Maybe someone just rode it hard? This is my first Pioneer and I'm impressed with it so far.
I emailed dwojo69 about the grain of wheat bulb. Tried to replace it with one from my local electronics shop today but the bulb was too large to fit.
Here are some pics of the unit.
