Guth
A while back I obtained a set of ADS L300e speakers. I found that the output of one tweeter was noticeably diminished. Using information I found on this forum (thanks to everyone here who has shared info regarding ADS speakers) I was able to disassemble the tweeter in question, check the state of the ferrofluid and carefully reassemble the unit trying to make sure everything lined up correctly. This alone resulted in the sonic success I was in search of . They are really fun little speakers and are quite enjoyable. Enough so that I ended up purchasing a set of L300W speakers (with the walnut veneer).
I was surprised to find a few notable differences (other than the tweeters) that I was not expecting. For one, the cabinet of the L300W design is deeper than that of the L300e (I didn't measure, but it looked to be at least 1/2" difference between the two designs. In addition, the L300e variation is notably heavier than the L300w variation. Has anyone else here had a chance to compare the various iterations of this little speaker? How do the L300 or the L300c compare to either the L300w or L300e when it comes to size and weight? Are there any other differences worth noting? Obviously this isn't a pressing matter, but I was simply curious and I appreciate the ADS knowledge that exists in this forum.
