Ishmael
We are awaiting the arrival of a pair of ADS L710 Series II speakers, which we hope can be driven by our Denon PMA-7.5L integrated amplifier. This integrated can actually double its power from 45 watts at 8 ohm to 90 watts at 4 ohm and has a matching Denon DSD-7.5L CD player. I have read several posts concerning how much power/what type of amplifier-receiver should be used to drive the L710. It was interesting to read that some were having great performance with lower powered amplification whereas others wanted/needed substantial power to drive this speaker.
Online I found sales brochures for the ADS L710 and the ADS L710 Series II wherein the specifications for each speaker are listed with interesting differences, which may in turn explain the different experiences reported in the posts mentioned above:
ADS L710
Frequency response 25-25,000 Hz (DIN)
Impedance 4 Ohms minimum
Efficiency 87 dB SPL at 2 Watt input at 10 ft. distance
Recommended amplifier power 15 Watt minimum
ADS L710 Series II
Frequency response 40-23,000 HZ (+/- 3dB)
25-30,000HZ (+/- 5dB)
Impedance 6 Ohms nominal 4 Ohms minimum
Nominal power rating 75 W
Musical Peak power rating 150 W
Efficiency 92 dB SPL (at 1 Watt RMS input at 1 meter)
In the posted photos of our speakers on the binding posts they make no mention to ADS L710 II or Series II. However, on close inspection they clearly state “75 WATTS NOMINAL 150 WATTS MAXIMUM 6 OHMS NOMINAL 4OHMS MINIMUM”. They are therefore ADS L710 Series II which raises the bar on the power needed with only 15 Watts reserve from the PMA-7.5Ls 90 Watts at 4 Ohm to drive the 75 Watts nominal needed by these speakers, though at 6 Ohms nominal/4 Ohms minimum. Is this an insufficient margin to safely drive these speakers? Given that they will be played in our main listening room adjacent to our main system with forays from time to time into robust classical music and classical rock and roll, but not usually past 9:00-11:00 on the volume control, even though we know this does not tell you much about the actual power being used.
Thanks for your thoughts-suggestions.
ADS L710
ADS L710 Series II
