ADS Model 300 Speakers
Original model I’m pretty sure. And I don’t think you need to replace the woofers. They look like rubber and should be good to go.
I never had plans on replacing the woofers, they are rubber surrounds, you may be confusing me with another poster, I was however contemplating giving the crossover an upgrade.
The model 300 is excellent. I bought two pair with rotted foam for cheap, maybe $20 a pair if I recall. I was able to refoam with rubber surrounds and listened to a pair in my office for 5 years before everyone started working from home.
I guess I will revive this old thread by saying that I just purchased a set of 300s that look to be in great shape, just some minor scuffs. The surrounds look fine but I will be searching for replacements, I will also replace the electrolytic cap but I assume its on the woofer and probably won't make much difference in sound. View attachment 2372640
Sorry, sounded to me like you intend to replace the woofers or the surrounds.
Yes, I can see why you would think that, I said that I would be looking for replacements, I forgot that I had wrote that but at the time I was thinking that they would have foam surrounds based on what some other people had said, I did not have the speakers in my possession yet, the photo was one from the original ad. I was happy when I unboxed them and they had rubber.
Just installed the new caps and binding post. I thought I would try a cap that I never used before and bought obbligato for the tweeters, when they arrived I thought that I made a big mistake, they are a lot larger than I was expecting, I was going to buy something smaller but I was able to make the giants fit, it involved installing the crossover board with the components facing the drivers. I used mills resistors and for the woofers I used a 24uf axon with a 1.0uf clarity cap just to keep the values exact, a 24uf would have been fine for the woofer though.
The binding post that I ordered were to big to fit in the recessed area where the spring clips are so I just mounted them by drilling a hole were the bottom hanging slots are, this was the best location due to extra material that look like large post inside the cabinet.
I am amazed at the sound these tiny bookshelf speakers put out, they do not sound like a small speaker. The new caps have made an improvement but I need to put some hours on them to determine if burn in will make them even better.
