I'm not sure about these not being "real" Advents, because while the two-way design has advantages over a 3 or more way
loudspeaker, that only works so far and then physics comes into play......and economics. Based on what I know about him, Henry Kloss wanted Advent to provide speakers with excellent performance for the money for those who could not afford something better, and one way to help reach that goal was to do a lot of in-depth research to design a 2-way system that performed nearly as well as a 3-way but which would cost much less. This was important because adding a midrange driver to a system increases costs significantly, not just because of the inclusion of the driver itself, but also its associated crossover which many times can cost more than the driver it's working with!*
But when work on the CD format was announced around 1980, which has a much wider dynamic range than the LP or cassette formats, the limitations of a 2-way design
intended for the more affordable end of the market become apparent, particularly power handling. Usually the tweeters in such a design, especially one that uses such a relatively large woofer like a Large Advent, have to be x'ed over at a rather low frequency vs. something with say a 6.5" woofer, which raises the chances they will be burned out by higher volume settings or unexpected spikes in volume i.e. crescendos in classical music or for rock/pop music, intense cymbal crashes for example.
What are you going to tell your potential customers who own the latest playback source, that your company's speakers will be O.K. as long as you're really careful with the volume knob? Uh huh, that won't work. Besides sounding darkly humorous it causes your company look like they are cranky stick-in-the-muds and worse, backwards technologically-speaking, NOT good for future success.
So the addition of a mid driver relieves much of the pressure power-wise on the tweeter because it can be x'ed over much higher and in turn reduces the chances of it being burned out. And more importantly as far as the music is concerned, doing this reduces the potential for distortion since the tweeter doesn't have to handle those lower frequencies. And at the other end of the baffle: now the relatively heavy 10" woofer doesn't have to deal with as much of the delicate upper midrange spectrum & in turn it can be better optimized for the lowest bass. FYI: at least according to the 6003 brochure I have, the woofer in the 6003 is a special version of the classic Advent ten incher.
this is because most mid xovers usually include not just a filter to eliminate the lower frequencies but also a filter to make sure the mid's output is rolled off at XXHz upper frequency where the tweeter takes over - so you could almost say there are actually two crossovers for a midrange
