Ishmael
I am in the process of restoring a pair of Advent Laureate speakers which I hope will solve the problem of a small room 9'x9', our office. Reading about them I learned of their bigger brother the Advent Heritage, however while there is very little to be found on the web on the Laureate there is quite a bit more on the Heritage.
In researching the Laureate I came across specifications which provided in part:
Frequency Response: 42Hz to 23 kHz
Freq. Range: Low 34Hz-8dB, High: 23kHz-3dB
For the Heritage I found an actual Advent brochure wherein it listed specifications in part:
Now this is where my head scratching began, as the Laureate makes do with a pair of 6.5" speakers for bass/mid-range, while the Heritage has a pair of 8" speakers for the same duties. How could their specifications be the same?
Are the posted specifications for the Laureate in error?
Does the volume of the sealed cabinet limit the frequency response and frequency range?
Has anyone heard the two speakers in comparison and what do your ears tell you?
Finally, if anyone has additional information on the Laureate it would be greatly appreciated as it has been hard to find on the web.
And yes, I am intrigued by the Heritage, you can see they had little details of additional quality built into them, fused tweeter (?), real binding post as opposed to the ubiquitous spring clips in the Laureate, and the pictures of the Heritage's 8' speakers appear to have substantial magnet motors (not that the Laureate's were lacking for their size).
Thanks for your thoughts.
