WillMeyer
I have a set of Advent Legacies the I just picked up. Of course it needed new foams and that is in process.
I'm a fan of the Jensen era Advents. I think they are good speakers and with just a little bit of tweeking become a much better speaker.
I've done a bunch of work on the Heritage, Laureates, Prodigies, and Babies. Typically, upgrading the caps to Metalized Polypropylene, adding additional polyfill, and upgrading the inductors yeild significant improvements. My approach has been to maintain the original design, and stick with the standard resistor values, capacitance, and inductor values - and I've been very pleased with the results.
This is my first Legacy and its different from the other Advents. These speakers were extrememly well loaded with sound insulation. There is more stuffing that I've ever seen before (observation not a complaint). My concern centers are the crossover. I've attached a drawing of the crossover, I make drawings for all the speakers I work. I'm extremely surprised that there is not crossover for the 10 inch woofer. The woofer gets the full range signal, and relies on the physical limitation of the speaker and its inability to produce high frequency. Part of me feels that there should be an inductor in series to limit the high frequency, yet I'm also torn towards leaving the original engineering.
Is anyone aware of a crossover mod for these? Advent uses this same woofer in the Maestros, but the crossover point would be different since the Maestros have a midrange.
I
I
