The low end with the OLA's just sound thin and lack presence.
I've never heard that from anyone while describing Large Advents. Did you ever check the polarity of the wires inside of the cabinet?
So, I may have found the problems with mine. Toed in, tilted back a little and they sound better. I was listening to David Bowie's Black Star album and these speakers sounded totally different. After playing verious other music repositioning them has helped. I'll have to get or make some stands to get the tweeters at ear level next.
The low end still isn't where I like it, but it is better. I guess I really am just used to ported speakers. I'm not a bass head, but these so far are the most relaxed set of speakers I've had when it comes to bass. I'm happy with the midrange and high end though.
Agree that this was not the original design goal but they are no longer in expensive and I feel even using old school drivers they could become much more/ better with a little modern know how.Which would defeat Henry's concept behind the design - a simple, inexpensive speaker that works pretty well across the range just shy of half an octave missing from either end. I find that the New Advent with the simpler, revised crossover improved the overall balance. I did, however, update the crossover components with mine, soldered the leads and put wool diffusers around the tweeters to minimize diffraction.
I run them in the garage system today driven by a 300 watt / channel Ncore amplifier.
I'm way over boomy speakers. I've been listening to records mostly and decided to try some CD's. The bass is better and while standing next to the speaker I noticed a high pitched sound that's there only through the phono. I may have a problem with that board. A tube loose or going bad. I did just move so I guess I need to open up the preamp. Its not the first time a tube started screaming at me.I hope you aren't mistaking mid bass hump with true bass. Often, speakers that have true, smooth, low bass response sound bass shy to those who are used to hearing "boomy" type bass from, typically, ported speakers. That happened to me back in the seventies when I first heard Advents.
When deep bass is really there, however, they reproduce it.
Doug
This pair has been with me since 1972. I must enjoy them. But they haven't been my primary speakers for 20 years.
I had OLA and Dahlquist DQ-10s at the same time and wish I had the skills needed to make a 3 way out of the Advent using the Philips 5060ad out of the Dahlquist. The Infinity Qb would be a good starting point as an example. Even the double OLA had a less than clear midrange that the 5060ad or modern equivalent might be able to solve...paging Pete Basel! Please.
Plus I can now, run the gain on my ST-70 amplifier wide open, before it had to be set around 10:00. And I now have a much fuller range of motion with the volume control on the passive preamp. The OLA's soumd pretty damn nice now. I just can't figure this one out.
