Concerning these speakers, I've put all work on them on hold as I needed to use them temporarily at church given our one powered column speaker with a built in sub we bought in 2017 won't power on anymore and we aren't in a position to replace it just yet.
While dealing with another stereo, I wanted to go active with the crossover and saw the Xkitz active crossovers.
So I thought about it and determined that maybe this three way active crossover
Notice to our customers: Due to ongoing supply line issues, we currently have a back-log of about 1 week. We will process orders in the order they come in. We apologize for the inconvenience. Thank you, Xkitz Bi-Amping or Tri-Amping your speakers is the single most powerful, low cost, and...
www.xkitz.com
Would be better than trying to figure out a passive crossover, although it would require three amplifiers.
Do y'all think that would be a better way to go and if so what reasonably priced amplifiers should I use? Amps need to be at least 100WPC at 8 ohms.
Now given these only go to about 40Hz, I would use a sub or two. I can then use this crossover
Notice to our customers: Due to ongoing supply line issues, we currently have a back-log of about 1 week. We will process orders in the order they come in. We apologize for the inconvenience. Thank you, Xkitz Bi-Amping your speakers is the single most powerful, low cost, and simplest way for...
www.xkitz.com
between the low out of the three way with a crossover frequency of 60Hz.
I would do 900Hz for the woofer to mid and 4.5kHz for the mid and tweeter.
I also learned about baffle step compensation and realized Advent's solution to that was to put foam on the baffle.
That fact is another reason why I really don't want to try and make the passive crossover proper as I could get it right without the foam and it may not sound right with the replacement foam.
The active crossover is nice as I can tweak the levels to where the drivers sound balanced.
However, what I may do is order the resistors needed to pad the midrange and tweeter properly and replace the foam then see how the speaker sounds. If it sounds good enough I may add the zobel networks as shown on the 6003 crossover and see how much the sound improves.
It could be that I won't need the active crossover.
