Advent modification
Status
Not open for further replies.
it is a frequency response shaping network to make up for the fact that the drivers are not mounted directly to a wall, but instead, like most other speakers, are mounted in a box set at some distance from the wall. now that i am running my double advents with something that has a tape loop (and seperate preamp and power amp) i might give it a try myself.
Alot of speakers have baffle step compensation networks built right into the crossover and/or are designed with particular drivers and particular box sizes so that the baffle step compensation is provided for by different sensitivity tweeter/woofer or by natural amplitude changes inherent in the drivers.
As popular as these speakers are on this site I am hoping for more responces to my inquiry. I like my large "new" Advents enough to take exception to the comments made about them by the designer of this tape loop gizmo. IMO
There is a free loaner available, why don't you try it before guessing about taking exception. I'm the author of that thread and it was actually just a passing interest of mine. Some made a major fuss about it, positive from those who tried it, strongly negative from one wannabe who never even tried it.
I considered posting mods to the crossover so that the line level circuit would not be needed but given all the fuss from a few negative posters, I found it not worth the hassle. I don't mind negative comments, but try hearing it first, and with the right speakers, LOL! The one negative guy, had Jensen 5002s, and never even considered trying the circuit, LOL!
Pete B.
I considered posting mods to the crossover so that the line level circuit would not be needed but given all the fuss from I found it not worth the hassle.
On many levels, no doubt. ;)
From my own measurements, I think I'd first go after the midrange peak passively with a notch filter, or better, a comprehensive crossover redesign. That IS the crossover region.
I recall reading an article describing the evolution of the dome tweeter which included some detail about the "fried egg" and why its approach to combining mid and high frequency capabilities was subsequently abandoned. Do you have a link to that?
I suppose there is some merit in pursuing those modern replacement tweeters that'll play down to 1 kHz, but, for my own part, I'm not convinced the woofer is all that competent, either, BSC notwithstanding.
Bottom line: They're not all what thrift store scroungers make them out to be, stacked or not, and yeah, they can be made into something else, better. So what? :dunno:
Hi Zilch,
I'm quite fussy about speakers, and I find the Advents with BSC to be more than decent. They're quite close to an expensive truly full range reference pair of commercial speakers that I have, even in A/B tests. Not exact, but very close, remember this was a casual experiment that I did, no major effort.
What's your taste in speakers Zilch, any commercial example that you find to be the best for home listening.
Ah, my opinion is that the woofer is remarkable in certain ways, Kloss knew what was important to optimize in a woofer. I have many comments over on the other board.
A notch would help, but I believe that full BSC better corrects the two major issues, and one minor. That screaming peak, a slight boxy quality, and a lack of very high end extension.
I'd say that they are a remarkable thrift store find, but not the ultimate in sound as several of the reviewers claimed back in the day. BSC takes them up several notches, especially with the extra headroom of a stacked pair. I do agree that the lobing is an issue as you reported, and there are ways around that.
I'm not familiar with the article that you're referring to, and I am up on the literature. Funny, fried egg, I sometimes call it a donut tweeter, wasn't fried egg the AR? Don't know but I do know the tweeter that you're referring to. I noticed a long time ago that a well designed cone midrange can act as an acoustical 2-way with the cone+dome handling the lower mid, and the dome mainly alone handling the high end. Kloss did this with smaller cone tweeters, and also somewhat in the early orange LA tweeter. I'd say that intermodulation distortion is the disadvantage, but mainly when the driver is pushed into non-linear operation.
The LA tweeter has equal wind and gap height maximizing efficiency, but making it have zero theoretical Xmax. It will compress and distort when pushed, and I would not doubt if this was seen as helpful to tell consumers to back off on the volume.
I do think that finding a modern replacement tweeter makes a lot of sense.
Have you tried LAs with 100W even 200W/ch?
Pete B.
I've been running JBL 4430s as my mains for 20 years here, so it's two-ways with constant-directivity horns/waveguides and HF compensation.
There's not a lot of that available commercially, and what IS available gets above $4500 a pair pretty quickly, which is why I do DIY. I can get beyond there using leading-edge components for about $1500 a pair, and bump vintage boxes significantly up for much less than that.
Right now, I've got OLAs and DIY Indignias side-by-side on the test stand, and in terms of listening preference, there is NO comparison. Yes, there's great good fun in listening to and messing with $10 thrift-store vintage fare, BUT, by the same token, little mileage or merit, in an absolute sense, in pretending loudspeaker design engineering has been asleep for 40 years.... :boring:
Pete I meant no disrespect, I only took exception with your characterization of the Advent sound. I am only familiar with vintage speaker systems and find the Advent exceptional for their size.
I would love to try the BSC. I tried to follow the description on how they are made. I have one question, is there a twisted pair of caps that just hang out in the air on each side ? I would get more specific but I do not have the diagram in front of me. I found the photo of the empty box with the circuit drawn on it the most helpful to a non-techy like me. Do you have anymore photos or diagrams.
Again no offense meant, I am just darn proud of my Advents.
Pete B.
Well Pete if you ever change your mind and post the crossover mods I for one would be interested. I have 2 pair of OLA's and 1 pair of NLA's. Only 1 OLA is hooked up because I prefer the sound of my Polk 10A's which are my mains. But always looking to improve my Advents. All my tape loops are occupied.
I with you Archie, I would rather mod the crossover.
Pete I think you may find more willing experimenter's here than at the other site. We have a bunch of tweakaholics here!
I like my OLA's . . . as Pete and Zilch have said, not the final word in sound quality, but very nice :thmbsp:
I have a soft spot in my heart for ALL of Henry Kloss' designs . . . I think it's very interesting to see how his designs evolved from the AR1, all the way up to his work at Cambridge Soundworks . . . he was all about bang for the buck, which I TOTALLY appreciate :yes:
For a guy that dislikes Advents so much, Zilch has an odd tendency to comment in every new Advent thread. I've often wondered what compels a person to do such a thing.
HUH?
I rather like them, actually.... :yes:
Every time I read a post by the Great One, I am overwhelmed with feelings of awe and inadequacy. What have I, nay what have we, done to deserve the presence of such genius? It is through misty eyes that I pen these few trivial utterings, so overwhelmed am I, that it is pointless to continue. I must retreat to my listening room and once more caress the fine veneer of my JBL's, secure in the fact that I am not inadequate. Yet, I have sinned. Forgive me my Advents. I am not perfect.
I....am a Human Being!!
Déjà Vu
Title: "Advent Modification"
OP @ #1: "What do you speaker technicians think?"
OP @ #4: "I was hoping for more responses to my inquiry."
C'mon, guyz, I was all but explicitly invited to this party.
[Just didn't have the "correct" answer, is all.... :p: ]
OP @ #4: "I was hoping for more responses to my inquiry"
You can come to my party any time. Just don't bring your slide rule>
Status
