Advent Prodigy II restoration
Very early stages of this one, but I pulled the woofers and tweeters and checked them with my DMM all test good at 6 ohms.
So I started work on the cabs. I cleaned everything first with a Magic Eraser. That seemed to help considerably on the black surfaces in particular.
I scraped the the remaining varnish from the wood tops and bottom panel. Sanded them down, starting with 40 grit and getting progressively higher.
Some of the stains were still in the wood, so I lightened them a bit with a mixture of oxi-clean and warm water by letting it sit and then wiping it off. A bit more sanding should do the trick.
I also started gluing up the splitting seams.
Opted for a danish oil (walnut) finish rather than a traditional stain. Brings out the grain quite nicely. Here they are after one coat:
AF90F034-CD17-4914-9FC6-966FF7ED6A23.jpeg 07D7E5A8-98DB-4507-9D34-9F17CAC664F7.jpeg 87BC85EA-E3A1-4CE1-ADA6-864C347BBF36.jpeg B64B840E-E538-4642-8084-C869B76F7A6E.jpeg
Another coat will darken them up just a bit.
All done. Woofers refoamed and reinstalled. A coat of paste wax over the entire boxes really brought them back to life:
672FEC14-4FE2-4042-8B3D-DAEAF107181B.jpeg EC68F699-FABD-4184-8A32-4664E163EDD5.jpeg E7846EE4-E0E7-4396-B7FB-60A54F39E92C.jpeg 132591CC-D1D9-4512-98E3-0526F1857D3B.jpeg
They’re in the bedroom system paired with a Tube Mini amp for low-level listening.
