OK. Basically what we will be doing is to take a mono interconnect, and plug one end into a Tape Monitor input of one channel -- either one, it doesn't make any difference, and turn the Tape Monitor switch ON.
Now, ideally, you will take a clip lead and clip one lead to the center pin of the other end of the interconnect, and then tape the interconnect/clip lead, not only so they don't come apart, but also so that the ground sleeve of the interconnect doesn't touch anything. Alternatively, if your careful, your can just use the pin of the RCA plug at the end of the interconnect, but attaching a clip lead would be safer.
If this operation is successful, you should then be able to turn the unit on, advance the volume considerably, and touch the clip on the free end of the clip lead with your finger (or alternatively, touch the tip of the RCA plug). You should hear a substantial hum. If this is so, then all is good.
Now, with the unit upside down, bottom cover off, turned on, turned to FM AUTO, tuned in to a known stereo station, and volume control turned to 12:00 noon, we will CAREFULLY be using the free end of the clip lead to probe different points in the unit and listen for the result.
First up, touch the clip to Test Point 4 on the schematic, and let me know the result!
Dave
Dave
