advice on belt replacement b&o rx2 tt
Sansushi
Well-Known Member
i need to replace the belt on b&o rx2 tt. the motor pulley is located front left under the top plate, Looks like i need to partially remove the top plate to thread the belt. Is the top plate just seated into the base and need to be pried up with small screwdriver? thanks
See the service manual available here in the library on this very website. See P. 6-1 for instructions on removing the top plate.
Rick
